KnotConnected
- Joined
- Aug 15, 2012
- 221
So, after replacing the lower unit due to corrosion last-minute this spring, I want to make d@mn sure whatever was causing it has been resolved. Before I put her in (1994 Larson Cabrio 280 single 7.4l Merc) I...
1) Stripped the paint around the lower unit about 1" (the bottom paint was all the way to & touching the lower unit)
2) Replaced all anodes (they were pretty worn)
3) Reconnected the grounding wire connecting the port drive trim actuator to the housing (it was disconnected)
4) Verified the mercathode is connected & wired properly.
I'd like to have the water / boat tested for electrolysis, but the meter and electrode are pretty pricey, so I don't want to make the investment unless I still have a problem.
Question being: Will the anodes first and foremost *always* corrode BEFORE the important stuff on the outdrive? If so, I can just constantly check the condition of the anodes, and if they're wasting away too quickly, I'll know I still have a problem.
HOWEVER, if this isn't necessarily always true, and the drive could be corroding *with* the anodes, then I want to pursue a resolution immediately and not wait until the anodes (and lower unit) show signs of corrosion.
