codyandamber
- Joined
- Apr 5, 2003
- 106
I just just put an electronic ignition on my 1985 351w. The boat ran perfect before, but the points were in need of replacing. After I put the kit in three things happened:<br /><br />1) There is now a slight hesitation when I start off slow. <br /><br />2) The tach is not correct. 36 mph and 2200 rpms now according to the tach. Of course, it is obvious it is running more rpms. <br /><br />3) It will not start when you are turning the motor over. I have to turn it over and let off the key and it will crank right up. <br /><br /><br />I added a coil with an internal resistor as required.<br /><br /><br />Any help would be greatly appreciated.
