Electronics and Electric Battery hookup
lljhoyer
I've read many posts about what to hook to what battery but some are either fuzzy or I'm extremely dense. Should ALL electric and electronics be hooked to the deep cycle and have ONLY the motor connected to the starting battery? OR? Thanks in advance for what I know will be excellent advise.
18rabbit
Re: Electronics and Electric Battery hookup
Here’s my 2-cents on battery configuration. It does differ from the other recommendation. My comments on dual-purpose batteries are at the bottom.<br /><br />A battery ‘bank’ can be anything from a single battery to 8 or 10 or more batteries. They are commonly referred to as either a ‘starting bank’ used primarily for starting applications, or a ‘house bank’ used primarily for all other nonessential electrical needs on a vessel. It is very common for smaller vessels to have a single battery stating bank and a single or double battery house bank. Some boats may have 3 banks where that third bank has enough batteries to supply appropriate current to 24v applications, like a trolling motor. The third bank is a ‘luxury’.<br /><br />You can think of your starting bank as “the necessities of life” and the house bank as “the luxuries of life”. Anything and everything that you absolutely need should go on the starting battery. This would include the ability to start your engine, your VHF radio (think safety), the instrument panel lights, and your navigation lights. This battery bank should be receiving enough charging current from the alternator while underway to support all of this low-amp stuff. At anchor, with engine off, none of this stuff is used (it's switched off) except the VHF and it doesn’t draw enough current to be an issue (1-amp/hour?). There is disagreement as to whether or not the anchor light should be supplied by the starting bank. I consider that single 25-watt bulb part of my navigation lights and have it configured to a starting bank that is sized appropriately.<br /><br />The luxuries you can (but probably prefer not to) live without are your (heaven forbid!) fishfinder, trolling motor (it’s looking bad), GPS (because you are smart enough to carry paper charts, too!), the RADAR, the stereo (it’s looking worse!), your electric beer cooler and/or margarita blender (why continue living?), etc. None of these things are required to ensure your safety and should not be allowed to interfere with your ability to start your engine(s).<br /><br />Configured this way, you can go off into the sunset, trolling until you kill your house bank beyond resuscitation, and still get home safely. At any given time there is between none and a very minimum load on your starting bank … actual engine starting excepted, of course. If you were to take you boat to any experienced, reputable boatyard that does marine elecrical and drop it off without any electrical wiring, your boat would come back with the wiring configured as described above. That anchor light may be wired to either bank…you should decide what works best for you.<br /><br />I am not a fan of dual-purpose batteries except where a small vessel has a single battery that is used infrequently to support both the ‘necessities’ and the ‘luxuries’. A dual-purpose battery is a deep cycle battery with inappropriately thin lead plates. This allows more surface area contact with the electrolyte, which results in more amps flying out of that critter for starting applications. It is not optimized for either deep cycling or starting and as such, any use means there is more internal chemical reaction (corrosion) than if using a battery that is application specific. It is the ‘odd child out’ but it does have its niche, albeit a small niche.<br /><br />If you consider AGM batteries, while not technically dual-purpose, they function well in either deep cycle or high-amp starting applications. They are a deep cycle battery with extremely low internal resistance. This allows them to spit out the high amps needed for starters. The newer generation of AGM’s is a deep cycle battery that will outperform a traditional flooded starting battery for staring applications. AGM’s are not cheap. Overall, I almost always consider an AGM a better alternative to a flooded dual-purpose battery. AGM’s aside, application specific batteries are almost always a better choice.
lljhoyer
Thanks both of you! Both posts have lotsa good info.
wilkin250r
I would disagree on one point from "ThomWV" in the linked thread. He states that in the "both" switch position, you are charging both batteries the same, which will lead to overcharging of one, and undercharging of the other. I don't see this as physically possible. <br /><br />The only way the "both" configuration would work is if both batteries are wired in parallel for that switch position. As such, they are bound by the laws of physics to have the exact same voltage, and it would be impossible to "overcharge" one without the other.
