Elgin outboard 1959 won't start
stewbedo
I was recently given this boat I have been trying to start It all day Gas leaks out of the hole below the motor. I think I been flooding It. I don't know much at all about boats. When I first attempted to start It at least it almost started. I waited an hour, then tried again. It just keeps cranking over but doesn't even sound like It is going to start. Then, this cloud of smoke comes out of the bottom.. Please Help......
iRich
Re: Elgin outboard 1959 won't start
how old is the gas? 2 cycle gas has oil in it and if it has been sitting for more than 60 days or so it is probably no good.<br /><br />Rich
rolmops
Hello.<br />I do not know what you know about engines in general, but do buy yourself a manual before going any farther.You can probably find a copy of your year in a public library.
Solittle
Spend a couple of hours browsing this forum and try out the red Search at the top of the page. You will find plenty of info to get you (not the motor) started. In general you want to find out if the spark plugs are sparking and the motor is getting fuel. The smoke you describe (exhaust) is a good indicator that you will be able to get it started.
steelespike
On these old motors that have been sitting around <br />fuel system is usually pretty gunked up.I recommend going through from tank to carb and clean, check and rebuild as required.<br /> If your motor is a 59 it was built for Sears<br />by West Bend Motors.
