phonephreak
- Joined
- May 1, 2005
- 11
I am still trying to id my Elgin outboard. I took the engine apart and found part #s: below carb:621-10342, side of engine:22010, underneath carb bowl:07802, underside of carb w/bowl off:07965, plate tht carb mounts to:22167, side of carb under Tillotson brand:MD4A, Metal trim ring around motor(not prt of tank):22038, pulley tht is attached to top of engine tht the pull start engages to:119456, and on rubber vibration dampner under motor above boat clamp. The motor is green, 2 cylinder. The spot on the tank where the serial # was, the paint is gone.
