elgin water pump
popsmazz1
I have a 1953 elgin 7.5 hp. how do I pull the leg to replace the water pump? I have no books that go back that far, thanks.
F_R
Re: elgin water pump
Shifter in gear, remove the metal clip from the front, and slide the lower shift cable out of the slot in the connector (don't have to loosen the screws). Remove the nuts/screws and drop the gearcase down.
Water Pump Impellers
popsmazz1
ok did that, replaced impeller with a spare, now the shift cable is stuck, is there suppossed to be spring pressure plulling down on the cable? it seems to be jammed in the neutral position.
