I have a 1998 75 hp Force with a single ram tilt. I was checking something at the back of the boat and grabbed the skeg to help get up and it made a click sound. To cut a long story short I traced it to the pin in the top of the tilt ram that connects it to the motor. It looks OK. No corrosion or cracks in the castings that I can see. I noticed the motor would move forward and back if pressure was applied. Measured at the bottom of the skeg it is about ? an inch. Almost all of the play is from movement at the pin. I don?t have much play anywhere else and the ram doesn?t leak down.
I?m thinking that this is normal but thought I?d ask all the same.
Thanks
Dean
Thanks
Dean
