Engine Alignment Tool: Absolutely Needed?
Chef Shawn
Hello All,
Just pulled the Mcm 140 out of the boat, did not pull lag bolts, left front engine mount exactly where it was, took careful measurements from various points on the front of the engine and dropped the new engine in (another 140). Measurements match. Rear engine mounts seem to have no adjustment, drive shaft slides in smoothly, without a problem. Am I safe, or should I spend the $50 on the alignment tool?
Thanks in advance.
MarkSee
Re: Engine Alignment Tool: Absolutely Needed?
Spend the money to buy it and check it.
Checking engine alignment should be part of your annual maintenance tasks.
Mark
PS: do you happen to live in SoCal? My alignment bar is one tool I have lent out to fellow IBOATERs before.
Hello All,
Thanks in advance.
Ayuh,.... Welcome Aboard,... Yes, ya gotta align it, Anytime the motor is moved, regardless how careful you were...
JASinIL2006
That's the same one I bought! Good investment...
Chef Shawn
Thanks everyone! I WISH I was in SoCal, but Northern Indiana will have to do for now...
Chef Shawn
Do I need the HINGE PIN TOOL as well?
Ayuh, only if yer changin' the bellows or lower shift cable...
I use a 1/2" allen key, myself....
