No Title
Hello guys. Just an update.
I drained the unit and pulled the drive. The drive oil looked great..no white..no metal flakes. The magnets were clean.
The bellows was full of drive lube and grease. The Gimbal bearing had .5" of a gap between the bearing and the inside ledge of the transom. I felt a broken oring on the inside side of the bearing. The bearing moved freely, with no binding whatsoever (only a few hours on it). I tried the alignment tool and it didnt go in perfect (i assume the bearing isn't nearly seated correctly)
Also, the metal ring for the bellows was missing. Not sure if that has an effect on the yoke seal leaking or not. The leaking actually stopped and the bottle has stayed full. I however have ordered a new oil seal ring to be installed by a DIFFERENT mechanic on Friday. Once he reseals the drive and pressure tests it. I will be ready to bolt it back on.
I now know that the noise was from the bearing not lined up and it was inserted nearly far enough. How does it back out away from the boat like that?
Here are all the pics.
Thanks,
Joe
