Engine Balance
Outrage 19
I have heard if you have scores in just one cylinder you only have to bore that cylinder. Doesn’t that throw the balance of the engine off because of the extra weight in that one oversized piston?
Dhadley
Re: Engine Balance
The oversized pistons are within tolerance of the standard pistons. If the others measure out OK then yes, you can oversize one cylinder.<br /><br />There have been several very good threads on the subject.<br /><br />Good luck!
Dhadley
Re: Engine Balance
Youre welcome. Hope that helps.<br /><br />Oh - the biggest and most important thing is to figure out why it scored a piston. We dont want a repeat situation.<br /><br />Good luck!
Outrage 19
Re: Engine Balance
I believe a bent reed valve caused one cylinder to lean out. Thanks again
Dhadley
Re: Engine Balance
That would do it!!<br /><br />Let us know how it turns out.
