Engine Bearing Noise? Squeals at idle but not when throttled up..????
Allmand
I have a 1966 inline 6 250 160HP gm...When the engine is idling I hear a on and off squeal, scream, and chirp coming from the motor. I checked the belts, greased the pully's and still the same sound. I put my ear next to the crankshaft area of the motor and it seams thats where its coming from. The sound could be telescoping, hard to tell with the engine in your ear. But its on and off....when you hear it you can almost invision a ball bearing going round and round squealing. But it starts at a mid squeal tone and rapidly increases in pitch until its a very high pitch squeal and then it stops, engine sounds great for a few minutes then starts it all over again, sometimes with a grinding type noise. When I give it gas it seems to go away. Oil clean, engine seems like its pumping oil, not sure if its pumping correctly. How does a bad crankshaft bearing sound?
Re: Engine Bearing Noise? Squeals at idle but not when throttled up..????
Ayuh,... They grind, not squeal...
Could be the belt, on bad pulleys, or the alternator, or waterpump, or ??
Don S
Front or back of the engine? Could be the gimbal bearing if coming from the back.
Fishermark
Remove the belt and see if it goes away. If it does, then it is either the belt squealing, or the water (circulating) pump, or the alternator.
Allmand
Thanks for the tips...I will try these things. I am going to get one of those stethescope deals that are made for automotive purposes and check it out too. If I still can't find the problem I will reply with video of the sound.
Thanks again
