Engine Bed Fabrication
markhodges78
So I'm getting closer to my engine change but not there yet but have a few more question's
for starters I will not be able to do the L bracket bolt thru option because there is no access to the back side of the stringer see attached photo below. So moving on I will have to make a mount from wood so ? number 1 what should I use to fab the bed from ( 4X4 1X1 or laminate plywood together) Then after the bed is formed it gets coated with a few coats of resin and after the mount gets attached to the stringer and floor of the boat using peanut butter ? once peanut butter is cured the engine bed gets glassed to the floor and the stringer..
Is this the way it should be done...
88 Capri (2022 SOTY)
Hi Mark,
I used 4x4's out of Douglas Fir and I know others used plywood laminated together.
Any wood needs to be thourghly coated with resin, 2 coats is what I did, then after I used my PB I put another coat over everything before I glassed.
Before any glassing make sure all gelcoat is removed and thourghly cleaned with acetone.
I'm sure others will give you examples of their techniques.
markhodges78
Hi Mark,
Thank you for your response and I look forward to more responses...
todhunter
Canoeist
On my restoration, I pulled the old engine mounts and cut them open to see what they were. Turns out they were a 2" piece of mahogany (very rot resistant) sandwiched between 3/4" plywood. The lag bolts go into the mahogany, so any moisture that gets in through the bolt holes is only impacting a rot-resistant wood. You can see pics of my engine mounts here (start there and scroll down and you can see them progress).
I coated them in resin, PB'd them into the boat, then covered them / tabbed them in with 2 layers of 1708.
I sandwiched layers of plywood, laminated together with tite-bond III or PB (depending on which resto).
each block was shaped with a saw (table saw, band saw or chain saw) and glued in-place to the stringers and hull with PB. then it was screwed to the stringers with 4" screws thru pre-drilled holes and the whole block was tabbed in place
markhodges78
Nice work you have going on here
Baylinerchuck
Mine were dimensional lumber glued together with PL, then PB’d in place. Multiple layers of 1708 to tab in place and build final height.
markhodges78
Tabing that brings me to my next question I know it's been said to start with your widest tabing and go down in size. But I've also seen someone that says they just can't wrap there head around the concept. And by doing it that way there's only 1 layer of tabing actually coming into contact with the glass below it. So they do the opposite and start with the smallest tabing and work up in size. What methods do you guys use...
stresspoint
always remember when laminating > a bond is only as good as the first layer , start small and work outward , sand back between layups.
Other way around. Each successive layer of tabbing is 2-3" wider in both directions. So your first strip is 6" wide, you next is 12", etc
markhodges78
This is my thought process as well but I've seen many say that you apply widest first. Like this video here at about 4:15. This concept just blows my mind I wanted to make sure my thought on this was agreeable
You should be looking in the forum stickies
specifically 4th sticky down. Links 14, 15, and 18
