engine beep
riversedge1
Wanted to see if anybody could help? I have a 1995 175 evinrude on my ranger and was out and went to start and got a solid steady beep and wouldnt start , was just setting on water so it was like when i pulled up and shut down it may have happened , looked back and bulb was deflated , changed bulb and got it started but would only run about 5 miles an hour and when i tried to get on plane it would start the beep again and shut down . i was able to get back to dock doing about 5 mile an hour for about 5 miles , any suggestions is greatly appreciated thank you so much !
If bulb is flat you have a restriction in your fuel supply.-----There is a vacuum switch that alarms for this.----Check tank venting.----Check pick up screen,.----Anti syphon valve , if equipped with that.
