ENGINE BLOCK
mthesurf
HELLO EVERYONE I HAVE A 1989 MAXUM BOAT I'M REFURBISHING,IT HAS A 3.O GM MOTOR JUST ONE PROBLEM THE BLOCK HAS ABOUT A 10" CRACK IN IT.ANYBODY KNOW WHERE I CAN PURCHASE JUST A PLAIN NEW BLOCK OR A GOOD USED ONE,ALL THE REST OF THE MOTOR IS FINE.THANKS
JasonJ
Re: ENGINE BLOCK
You could try an auto salvage yard. You may have to have the block reconditioned, but that is most likely going to be your most economical source. There is no such thing as a marine specific block. These GM motors differ from their automotive version only in the periferal sense. You'll need to find out what cars this engine came in to make the hunt easier. Good luck....
Realgun
Re: ENGINE BLOCK
Actually GM did noy use a 3.0L 4cyl in any car.
mthesurf
Re: ENGINE BLOCK
LOOKS LIKE YOU TOOK ON QUITE THE PROJECT LOOKING GOOD THANKS FOR THE INPUT.
JasonJ
Re: ENGINE BLOCK
Realgun, I was sort of thinking about that. Could it be OMCs version of the Mercruiser 3.7 liter 470 where they used a Ford 460 head on an aluminum Merc block designed for the 470? He never said how many cylinders his engine was, or if it was Volvo/Penta, Mercruiser, or OMC. Is it a small V-6, an inline 6, or a large 4 cylinder? Guess that question needs to be answered as well as who's name is on the valve cover.
Re: ENGINE BLOCK
3.O GM MOTOR
Same motor is used by All the marine drives.....<br /><br />Hasn't been used in a car in over 40 years.........<br /><br />It's a Marine/ Industrial motor....<br />Try ebay.....<br /><br />I've got a Complete 3.0l Merc. Alpha 1....<br />But No bare Blocks.......
davidcrk1
Re: ENGINE BLOCK
I recently came across an extra boat that I have been using for parts. Next year I'll upgrade to a 4.3 but I do have a fairly good 3.0 block I'll let go of cheap.
