I have an engine bog that I cant seem to cure. The motor will idle fine but fall on its face when you gas it up real quick. When it first started doing this I could pull the choke a bit to clear it up, then it progressed to running it on full choke full time. Anyways last nite I cleaned the carb and put it back together thinking that there must be some gunk inside. The carb was pretty clean with a little tarnish but I cleaned it all anyways. It ran good in my barrel last night so I decided to take it for a test run today. I still have the bog when I take off but I can run full throttle now without the choke if I feather the throttle to full real slowly. Any suggestion?
Also, I have a dial for the lean to rich for low speeds, when the bog happens it seems to help if I turn it to more rich. Does anyone know how far this dial should be turned counterclockwise after tightening all the way to the lean side?
Thanks Jason
Thanks Jason
