chesapeakeclassic
- Joined
- Mar 8, 2012
- 7
I recently repowered my boat (24' chesapeake classic side console crab boat with full canopy) with a volvo 230B with a sp-c drive that came from another boat (18ft glastron bass boat style). I previously had a 250B/aq151 with 2 carbs with a sp-c drive. With the twin carb setup I could run 20-22mph with no problem at approx 3800rpm. New setup my top speed before engine starts to bog is 17 mph at best. All compression checks are 150psi, carb has been rebuilt and set perfect. The new engine and drive run great at idle and while under way with one exception. When I accelerate hard to full throttle past 3150 RPM, the engine starts to bog as if flooding or starving for fuel after approx 1 mile of full throttle. If I leave the throttle at full, the engine eventually slows and starts to backfire through the carb. If i back off the throttle to below 3200 RPM the boat continues to run strong but will not go past 3150rpms without bogging. Also with no load running the engine at the slip the motor will easily rev to 5000rpm. I recently replaced all rubber fuel lines, and checked the anti siphon valve to try to address the problem with no success. Has anyone had similar problems, or can anyone give some ideas to help troubleshoot. To help, ignition components such as wires, plugs, dist cap, rotor and points are new or in like new condition. Any help appreciated.
