Engine bogs down an locks up
TxGent40
Have a 86 merc 90hp inlijne 6. Can start it up an get going full throttle and after 30 secs it starts bogging down to point of seizing motor up if ya don't turn of the key. Then it won't turn over till it's sat little bit then runs rough for a bit an smooths out and ya can take off and does the same thing all over again. Thanks for any help!
flyingscott
Replace your waterpumpj before you do any more damage.
TxGent40
Even if water is coming out of the telltale hole?
can it still come out there and still not make it up into the motor to cool it? Shouldn't that make my motor overheat alarm go off? And if so I guess it's not working cause it never went off.
Faztbullet
If it has done this several times the damage is done...just a matter of time when it (motor) fails. Impeller replacement is too late.
TxGent40
First 4 or trips out were fine then the last 8 trips out half the time it happened an trolled back. Guess change it an see how long it last.
TxGent40
Quicksilver oil in the injector. Have had some say get rid of it and some say keep it cause it doesn't foul your plugs like running 50:1 mixture
flyingscott
Do you have the external autoblend system? If you do get rid of it and run 50-1 mix in it.
Agreed-----Throw that auto blend away as far as you can.-----Now do a compression test !-----50: does not foul plugs on a properly tuned engine.----Not sure where that idea comes from.
