I just bought a 1985 sunrunner 18' boat with a Mercruiser 140 engine. The model # of the engine is MCM 140, s/n A412106, 181c.i. 3.o liter 4 cylinder. I put the flush muffs and garden hose on it and ran it for 3 to 4 minutes and shut it off. The temp gauge was up to about 200 degrees and it sounded like something was boiling in the engine. Is the boiling sound normal and what should the temp gauge get up to? I'm a mechanic but I work on construction equipment and don't know much about boat motors. Also the boat has an oildyne trim/pump in it. The coupler between the pump and motor is cracked and needs to be replaced. I've got the sierra p/n for it (803852) but can't find anyplace that sells them. Any help would be appreciated
Thank You
Terry
Thank You
Terry
