Re: engine cleaner
I did a search in these forums on "Decarbonization" and had found some good posts on this. I then took the advice of 12footer and some others on the brand of spray to use. I ended up using the Deep Creep made by Sea Foam, that I got at NAPA for $4.99 a can. I ran this through my engine as it said, let it sit about 20 minutes and then ran the engine again for about 25 minutes to get it all out. Using the water muffs, then took it to the lake the next day. I was able to get about a 4 mph increase on my speed from 3-4 weeks earlier.<br /><br />This stuff is what 12footer swears by, and I now used it in my car also, which it restored quite a bit of power that engine also. A 1994 Jeep Grand Cherokee, with the 5.2 V8, 132,000 miles. I ran only about half a can of Deep Creep through it, and then drove it, it ran like a champ. I definetly am going to use this stuff some more, to clean them both up completely.<br /><br />Hope this helps,<br />Bryan Cox
