My cuddy is kept on a trailer with a fitted canvas cover. There is always some water in the bilge from boating and rain.<br /><br />When the temperature rises, the bilge water condenses and soaks the inside of the plywood/carpeted engine cover. Worse, that moisture forms drops that then drip all over the engine. Some days the top of the engine looks like it was hosed.<br /><br />What can done to reduce this moisture problem? Should I cut one or more 3" holes in the top of the engine cover and install vents?<br /><br />My new engine will be installed soon. I don't want it to suffer this moisture like the present one.
