Re: Engine Compartment Storage
I've got quite a bit of space in mine. There are nets on both sides of the engine to keep things off of it. You can definitely store stuff there like life jackets, tools, rope, anchor, basically anything that will fit. You want to keep the water/moisture factor in mind though and be sure that you don't put things in there that you don't want to get wet (unless they're in a protected bag or something). Not positive on the temperature factor, but assume that it can get pretty hot in there, especially on longer runs.
