Engine coupler adapter???
johnnyrich10
I have a chevey 350 i am in the process of swapping over all the marine stuff from my cacked block. Do i need some kind of adapter to install the coupler or just need to find some longer replacemant bolts to mount it. the mercruiser motor the bolts are atached and the flywheel and engine coupler slide on them and bolt down with washers and nuts. On the chevy 350 the flywheel is bolted on.. what is the process to fix this?
Thanks
Don S
Re: Engine coupler adapter???
Take the studs and nuts out of the crankshaft from the old engine and put them in the new engine.
johnnyrich10
Thanks Don, i was hoping it would be an easy answer. This forum is great :)
