Engine cover / Dog house...Can these be purchased?
kfraser
I searched the net and checked several parts dealers and can not find anyone that stocks engine covers. I'd like to find a fiberglass or plastic / composite engine cover. I'd hate to have to build the replacement out of wood as the original just rotted away over time.
p12
Re: Engine cover / Dog house...Can these be purchased?
i'd think that you could get one used out of an old boat and recover/refinish it. Though i don't believe there are any standards, due to similarity of boats they are often similar enough to use if you are redoing your interior.<br /><br />They often have flat edges and are of similiar heights. For example, the one on my sea ray or sylvan could be put in the other boat if i were redoing the surrounding area. Both boats have fiberglass engine covers.<br /><br />Mike<br /><br />Good luck
Boomyal
Lay one up yourself kfraser.
Eggkr8
If you still have the old one, you could use it as a mold to make a fiberglass one
JasonJ
Just build another out of wood, and glass it up with a layer of epoxy/cloth. Line the inside with Duramat to deaden the sound then upholster or paint or whatever, it will never rot again. Good luck...
tailend63
I am also look for plans for dog house for Galaxy 199 1986 any help would be most appricated.
lcrayne
Jason - What is Duramat and where do you buy it?
jlinder
I second the question on Duramat
kfraser
Not sure what the duramat is. I tried a google and came up with Duramat Vinyl Office Chair Mats? I decided that I'm going to go with a little different set up. I'm going to build an engine compartment that spans the width of the boat with a sun pad on top. The top will raise straight up somewhat like the hi-performance go-fasts. The face or "front" will be hinged and will lay flat against the deck for engine access. I will loose the two jump seats that were next to the old dog house, but I'll be adding a cooler seat in front of the new one. Still should have room for seating six.
lakelivin
