Hey everyone,
Long story short as ive posted a few times in the past couple months. I had a 1993 4.3 mercruiser. My motor blew so I bought a used one. I replaced it with a 1989 4.3. Everything matched up, wiring harness and all. It was completely cold when I showed up. I started it a few times with no issues, cranked perfectly and ran awesome. Only part I had to replace was the starter slave solenoid (he had it bypassed). I took the solenoid off of my old engine that I never had any problems with and hooked it up.
Last night after I installed the engine I went to start it and got smoke coming from the battery terminals (extremely hot and nearly glowing red on the ground) and it was cranking over slowly. The battery was completely charged and I did test it. So I cleaned all my terminals and the ground from the engine block to the battery. Starter wasnt hot at any time nor were any of the wires to the starter. I tried started the boat again 3 or 4 times and the cables did not heat up the first couple times but it was still cranking over slowly. I checked all other connections again for heat without taking anything off and tried again. But once again I got smoke and heat on both positive and negative terminals on the battery... the boat wont start of course and im at a loss. any help would be appreciated. thank you!!!
