Engine cranks...starts to start, then dies
Skyhog
If i hit the starter, it cranks, then begins to run for about 1 second and dies....tells me it's getting spark and fuel, but failing to stay started.
Ideas?
Edit: this isn't really engine specific, but in posted it in the wrong forum. It should be in the Volvo penta forum.
southkogs
Topic moved. Might help to add some details about the drive and engine.
blamtro
Water in fuel, try changing your water sep/fuel filter or moisture in distributor cap
Skyhog
Ok. It's a Volvo Pents 3.0L.
Here's a video of me trying to start it
Ayuh,.... The ignition is powered by the outboard tiny terminal on the starter's solenoid, when the starter is engaged,.....
When ya release the key, the ignition circuit from the key switch takes over,.....
So,..... With a test light, check to see if there's power at the purple wire from the key to the tiny (+) terminal on the coil,.....
Skyhog
I'm not really following unfortunately. Are you saying that the red/yellow powers the starter, after which the purple wire powers the coil?
if so, I should be able to turn the key on and check for 12v at the coil right?
Skyhog
Let's add to that. My coil has the wiring harness on it. No positive connection. How do I test for power without splicing into the wire?
I tried to unplug it and tested the purple wire. No 12v. Is it safe to cut that wire and run a lead up to the switched purple wire on the key instead?
Skyhog
That seemed to do it. I traced the purple wire between the starter and the coil and spliced into it and ran a new run to the ignition switc . Started right up.
Unfortunately, it bypassed my skill switch so now I need to wire that back up too
