hello I'm new on here. I need some direction.. I have just installed a short block 5.0gm GXI-E engine in a 2005 auzra deck boat. Yes I took a truck 305 vortec put new rod and main bearings honed it installed new rings and installed the factory marine cam. I used the heads off of the original boat engine because it only had 100 hours on it .. they didn't winterize it and the original block cracked.. anyways everything is together and running . oil psi good starts good accelerates fine but when your at a steady rpm anything after 3200 up to 4800 its cuts out spits sputters kind of like a misfire it will do it on the water or in neutral on the trailer. Installed new thermostat different cap new spark plugs, distributer is installed correctly. I have moved the distributor around if I retard the timing it starts cutting out at 2000 rpm if I advance the timing it starts cutting our after 3200. what would be the proper readings in ohms to test the computer temp sensor.. I'm wondering if its running rich.. what is the symptoms of the black paint chips in the fuel system I did find some on the screen of the fuel psi regulator. fuel psi on the rail is 50lbs haven't been able to test low side because I don't have the correct adaptor. but it is pumping and has some pressure when I push in the Schrader valve.... I am stumped and this guy is wanting his boat back asap. its almost like it is hitting the rpm limit of a rev limiter but it will continue to climb up in rpm cutting out the entire time .
