engine damage?
jethro66
Hey guys a question here.I attempted a decarb today in a barrel and let it rum for 2 or three minutes and noticed it was not pumping water.Probably critters in side.How long can a engine go without water?I did not notice from all the smoke.I did not restart it, have to check the lu and flush it. is it toast?
freddyray21
Re: engine damage?
change the impeller and get it pumping again. Do a compression test to see if it has good compression. You may not have hurt it, but a few tests will tell.
CBINMN
Re: engine damage?
Assuming you have one you may want to check telltale tube to see if it is plugged also.
