david_r
- Joined
- Aug 11, 2008
- 1,118
i wasnt sure where to post this since my question is a little about depth and a little about my jackplate.
i have already asked a similar question on my other boats so i know where the anti-cavitation plate should ride in relation to the water.
my concern is: how can i properly check the wot depth on a ranger 350v?
the seating is pretty much in the center of the boat so when i have someone crawl to the back im worried the eng will be a little deeper than normal due to the change/distribution in weight.
i tried attaching a mirror to a pole so i could see the water depth on the plate at wot but i couldnt see real good, and the larger the mirror the harder it is to hold it steady while bouncing across the water.
another concern is the jackplate... it is manual so when i raise it up are there any notches or do i have to just try to turn each bolt the equal amount of turns and measure?
sorry if my question is in the wrong forum
thanks for the help
thanks for the help
