I had this problem on my '81 Johnson 70HP 2-stroke. I had puddling from the motor being pitched up too much. Adjusted it one notch down, and it stopped.
I also rebuilt my carbs, blew everything out with carb cleaner and compressed air. Make sure your floats are properly adjusted as well, should sit parallel to base of carb when held upside down.
Another thing I came across was at the top of the carbs there is a low speed idle needle. On my carbs it was a screw, not a needle. (if you do have just a screw above each of the carb openings, make sure the screw is all the way in and snug). If they are screws with flat ends, then don't worry about reading the following. Some older models had a needle above the carb opening to control low speed idle and fuel/air. Starting with center carb, slowly screw in 1/4 of a turn until the engine starts spitting or raises in rpms. Slowly back out screw until running smooth. Repeat for other cylinders.
Hope this helps, it took me a few trials to get it right. if you can, adjust in water or in test bucket. Running the engine off muffs isn't the same as it being in the water.
