A few times when I was on the lake last, if I would run the engine for a few miles, and then start to idle around (watching the depth finder), and then try to take off again, it would act like it had no fuel. So, naturally, I would go check the primer bulb, pump it up, and go for it. The bulb would be deflated each time.<br /><br />I replaced the bulb, and had the same problem (not everytime though, which is what is weird.<br /><br />Any idea on what may cause this? Could I have a kink/pinhole in my fuel line? I did notice that my fuel line does make a 270* turn from the rigging tube to go out of the access hatch, and to the outboard. But, everyone with my boat has this...and it works for them.<br /><br />I can't see any fuel leaks anywhere, so I am against the idea that there is a pinhole.<br /><br />Maybe my fuel pump? Filter is clean.<br /><br />Thanks for any help!<br /><br />Shawn
