I have a1981 75hp Evinrude, the engine will die as soon as I shift into gear, I have rebuilt the carbs, syncronized, set timing both low speed and high speed all to spec according to the manual, on the water and in neutral the rpm is 750 but as soon as I shift into forward or reverse the engine will die. Engine runs smooth at idle and in neutral, and runs good at low, mid and topin speeds.
