fbriggs
- Joined
- Mar 30, 2017
- 24
[h=2]Engine dies when trim down[/h] Yesterday, 09:32 AM
Ok so here is my problem. Have a 70 hp merc 3 cyl that on muffs runs perfect, once in water only way it will idle is with trim up, as you start to lower engine the further you get under water the lower the rpm goes. When all way down engine dies after 10 sec or so. If I start to raise engine it stays idleing.
Idle set at 850-900, timing at 8 degrees, carbs new, linkage and sync adjusted, timing advances correctly.
Have had someone tell me to bump up timing, tried but have to go all the way to 15 degrees before engine works and stays idleing, just not sure if I should leave timing that far advanced.
Any suggestions.
Any suggestions.
