Engine doesnt even try to start
thelightning
Hello,
I just got a 1997 Yamaha (VETO) 40HP this weekend and hooked it up to my boat.
I tried to give it a test start but it does nothing, it does not even try to start, the startmotor wont turn. I checked if it was stuck but no, i could move it freely.
All i did was connected the shift/speed wires and the big black plug on the motor. And ofcourse the battery.
The trim&tilt works fine, the ignition oil light goes on on my rev gauge, but the startmotor wont run :(
Anyone have any idea? i already tried a diffrent battery.
Thanks
bgbass.1
Re: Engine doesnt even try to start
get a jumper cable hook to positive stud and other end to a full charged battery if it spins you know its not starter
JB
Check out "Outboard won't start" in Engine FAQs, TL.
Hoss
make sure you have a good ground. a faulty ground can be the cause for a lot of starting problems.
thelightning
Shift is in neutral,
I just connected the startmotor straight from the battery and it worked fine.
The fuse is also intact. but still nothing when starting with key :(
Asainz320
Check the selenoid, it might be bad. Check and see if you get current to the selenoid when you turn the key. :)
steelespike
Check that the neutral safety switch is adjusted correctly and working.
usually it is at the controls.
gearyg
Do you have a lanyard (safety kill switch)?
Asainz320
I thought the kill switch was only there to kill the spark to the plugs, not the entire electricity to the engine.
mokaction
GET THE MANUAL.. Then problem solved.. Good luck.. You can go to ebay.com or amazon.com to find it..
Larry
