jmarty10
- Joined
- Aug 6, 2007
- 560
This is my fourth year of boat ownership and I as I read more posts I learn alot and build more confidence. I have 2008 4.3l merc with and alpha one drive that is raw water cooled. Yesterday, I sucessfully changed the engine oil and gear lube. I also opened up all five blue drain plugs to my engine. It gushed water from all areas (This is good) I know from reading posts that all the water my not be drained. Can anyone verify which hoses I have to pull off? There are 4 hoses in front of the engine in front of the carburator. I'm a little nervous about this because I dont want to fail at draining everything. Once that is complete I would like to enter anti freeze into engine block and manifolds so knowing what hose to put antifreeze into would be helpful.
Next year I want to pull the drive and try and change the water pump and grease the internals. Thanks
