engine drain
imported_TheMan
Re: engine drain
If fresh water, I wouldn't bother worrying about it until it is time to winterize.
If it is salt/brackish water you need to flush the engine with fresh water each time when you get back...
BAproject
Re: engine drain
only when you winterize...but not always necessary, you can winterize by running antifreeze through pump in the outdrvie....
