Engine draining question
dvan1901
I have a 2007 Mercruiser 5.0MPI with the multi-point drain system. I Keep my boat in the water, but it is supposed to get near freezing the next two nights so I would like to drain my engine block; I wasn't planning on pulling the boat out yet; so, my question is, can I drain the manifolds and block while the boat is still in the water without flooding the bilge area due to water continuously coming in? I was planning on pulling the hoses at the manifolds and block, and not using the blue plugs (don't trust them). I do not have an intake shut-off valve (yet). Make sense?
HT32BSX115
Re: Engine draining question
That's a great idea. Since the single point system will only work until the engine starts making rust then it will CAUSE you to have a cracked block/manifolds.
It depends on where your water line is compared to the engine. You might have a continuous flow of water since most engines are sitting slightly below the water line. The only way to prevent it is to put a shut-off valve in the raw water line from the transom.
If it's "near" freezing at the water, it won't cause a frozen block over night.
It'll need to be well below freezing to freeze an engine that is "on the water".
Now, having said that I would be worried too since "near" freezing can frequently be "below" freezing. [When do the WX people EVER get it right??:rolleyes: ]
You could probably add a valve to the raw water hose from the transom using a Sched 40 PVC ball-valve. That way you can turn it off. Bad thing is that if you do get a (real cold) snap freeze you could break the valve and flood the boat.
This is all so academic.......If it's only going to get to say 28*F tonight, you're probably safe. If you have power get one of those heaters designed for this purpose. (But I wouldn't rely on it for a cold winter.....power goes off sometimes !)
If it were me......I'd pull the boat and call it quits for the winter.
YMMV as it were....
Regards,
Rick
dvan1901
I pulled it and drained it, just to be safe. Only for a few days then it is supposed to warm up again. I am planning on having a valve installed on the intake side so I can not worry about it; not a pvc, but brass.
Ayuh,... If you insist, use Bronze, not Brass....
But,...
It's Totally Unnecessary,... draining the motor will not flood the hull,...
We're talking only a couple of gallons,... It won't keep flowing in...
Glad to hear you Don't trust it,... Those are a Sure Bet for a Cracked block eventually....
Drain plugs, At the drains are the Best way to go....
