engine failure my fault ?
paleo10
my 90 hp force gave up the bearing on the wristpin on the piston appears to have come unwound causing the rod to break at the wrist pin gas was mixed 40:1 , could this have been prevented i only had it one month my next motor will be on next week it is an 88 125 force i hope the blow up was just a fluke any ideas please
paleo10
Re: engine failure my fault ?
can this have been detected sooner there was no noise or loss of power before this happend
Frank Acampora
If you are married, you already know that it is always your fault!
Seriously, this sounds like one of those part failures due to a weak rod or just age on the bearings. I've never seen the small end go though--It seems to always be the bis end. It gets a lot more rotation and abuse.
If you had this engine only one month, you really don't know the history of it. Previous owner may have abused it, may have stored it for long period without enough oil causing bearings to rust--etc.
Rob454
Your oil mix had nothign to do with it. Sounds like a simple bad part that had a flaw. it jsut so happend to go bad when you owned it
Rob
