I flushed while in the water and the hose started collapsing but it didn't overheat so water was still circulating. Is it ok to keep flushing if hose squeezes together or will it squeeze tight enough to block the water from circulating? I didn't rev the engine by the way, idle only..... I stopped flushing because I was afraid that the water would not be enough. I then ran it in the salt water w/out the ears. circulated fine so I know I didn't damage the impeller. The water sounded like it was still circulating anyways but I just want some opinions.... I have heard of this in other threads
