crawdadric
- Joined
- Nov 29, 2005
- 88
1985 Sea Ray SRV300 with twin 5.7L Mercruisers and alpha I outdrives. Sea water cooling without an engine mounted sea water pump (water pump in Outdrive).
This might be a little long, please bare with me. Currently my boat is dry stored and this spring I will be keeping her at a marina in a wet slip.
I'm looking into an engine flush system that uses three ball valves. The valves use a "T" connector and installed inline with the hose from the Outdrive supply to the engine thermostat housing. One valve cuts off the Outdrive supply, the other cuts off supply to the engine and the third valve allows supply from a garden hose.
When flushing (engine running) you connect the garden hose and open its valve then close the valve coming from the Outdrive. This will flush the engine with tap water. Then you shut down the engine and close the engine supply valve and open the Outdrive supply valve to back flush the Outdrive.
My question is - when you run the engine and cut off the Outdrive supply valve, will this cause the water pump in the Outdrive to fail because of pressure build up?
