76SeaRay
- Joined
- Aug 24, 2017
- 1,071
So, I am trying to sort out how the brackets and harness gets routed on my engine. This is an older harness from what I can tell since it has a square Thunderbolt IV Ignition Module as part of the harness. It appears the shift bracket gets attached to the Starboard Exhaust Riser and the harness plug then points in front of the riser. The TB IV module is attached to the Port Exhaust Riser. I believe the alternator wire was intended for an alternator high on the starboard side so it is too short to reach the alternator low on the port side. I can add length to reach the port side.
So, my questions are:
1) How or where does the alternator get routed to go from the harness Y to the alternator low on the port side?
2) The two small alternator wires were taped off in the harness as not used. Would that likely have been for a one wire alternator setup?
3) How or where does the circuit breaker bracket get mounted?
4) In the picture labeled "what" there are two questions, a) is this the cable to the starter and b) what is the part that looks like a big lug. Is it a lug or maybe a fuse? Where does it connect?
Alternator Wire?
Circuit Breaker Bracket
What is This?
For reference here is the shift bracket. Does the circuit breaker bracket attach to this?
Thanks..............
Alternator Wire?
What is This?
