johnson1989
- Joined
- Apr 16, 2007
- 110
This engine was purchase ran good but overheated. We repalced Water pump, Tstats and still overheated. We then replaced the water deflectors and that corrected the problem. Doesnt over heat. We where able to get it up to speed but now it boggs down bad, like it has no power. Replaced fuel filter, tried new coils, New Plugs, and still no change. I will check the Compression and Test the coils tonight. After the new plugs where put it in it looked as thougt the left bank was not firiing. The plugs where really clean, RIght bank you could tell had been firing. Am I looking at a power pack now, or did something get messed up replacing the Water deflectors? We replaced the head gasket and torqued to specifications. Thank you
