Re: Engine height
I agree that then engine needs to be raised and you have 3 open slots in your transom bracket to do that. The other thing that raising the engine will do is reduce the tendency for it to dig your transom in. Just look at your trim position in the second picture for example. You have a shovel back there headed for the deep six. The more you trim out the more it digs, to the point that it could easily be part of your overall problem with top speed and diversity in your readings.
I realize you have a steep deadrise, but still, once you get that antivent plate above the water coming out from under the boat, the boat will set the attitude and the prop will do more of a propelling job and not so much an attitude determining factor. You will let the hull perform the way it was designed.
Expect your rpms to come up when you do this (raise the engine) and you may have to run with reduced trim to keep from blowing out, but as stated, that may allow for increased top speed for a given trim level as compared to your current position. I'd put on a prop, take data, analyze it and put on another. Obviously if you have a higher pitched prop running you at/near redline, you don't want to put on a lower pitched prop.
Other thing is that this is cupping is important. The better the cupping, the less your chances of blowing out at a given trim level.
I have personally experienced what I have said in here about engine heigh, effects, and blow out, so I do not have a problem suggesting it to you. I know it works!
Would appreciate feedback from you as to what you do and what were your results.
Mark
