So it all started out last summer i noticed that my head gasket was leaking water out the side and down the block so while out on a road last summer she finally died. white smoke all through the water. So after that trip i got home and pulled the head off and replaced the gaskets and put everything right back just as i took it off. I didnt get a chance to check the timing but i marked everything and put it all back the same way. No problems. Started it up and it fired right over.
This year about a month ago was the first time putting it in the water after the head change out project. I noticed that once you would put a load on the motor it didnt have as much power as it had before the head repair. it took i really long time to get up on plane. Once on plane the top speed would be 32mph when before was around 42mph. Also the oil pressure would read 80 psi when use to be around 40 to 50psi.
I thought the fuel filter needed changed. i put a new one on and took the boat out yesterday in the chesapeake. I noticed alittle bit more but nothing big. still top speed of 32mph. oil pressure was 80. I was running for about 20 min and she just died. dead in the water. oil pressure went. i tried to start and it sounded really rough. After letting it sit for about an hour i tried it again and she fired over. To get back to the lunch i just went really slow and she did it again after about 20 more min. I could not get it to start and had to be pulled back.
Any ideas on what this could be or what i need to pull apart to fix this?
I was thinking maybe a new impeller kit, and thermostat maybe. Could it be over heating???
thanks guys
thanks guys
