actaeon9
- Joined
- Sep 22, 2008
- 32
Hi All,
I have a 1988 Mercruiser 165 4 Cyl 3.7L engine in my Wellcraft 190 Classic. Is this considered the same as the "Oh so dreaded" "470"? I see numerous posts on here that I should run away with it once it starts to have problems.
Also as a side note - I have a pretty pronounced left to right shake in the alpha one outdrive. At low speed (idle but in gear) I can feel it in the wheel but it's not a constant. On Plane its less noticeable in the wheel (and constant), but if you look at the outdrive you can physically see it moving left to right in a "shaking" motion. It's about an inch right to left or so. The skeg is bent, could this cause a this much of a "Shake" though? I had the Prop redone last year.
Thanks
Thanks
