1986 OMC Cobra 2.5 L<br />Has sat for 5 years. I did a lot to prepare for running(See below).<br /><br />The problem is that when engaging the drive the engine misses, shakes and knocks loudly. When idiling or in neutral it runs fine. Have run it to 2500 RPM's in neutral...sounds great no miss or knock. Only does it in gear.<br /> <br />put in new this last two weeks:<br />fuel pump - points - condensor - rebuilt carb<br />thermostat - drained / cleaned fuel tank - new gas - new fuel filters (carb & fuel pump)- new spark plugs - new battery<br /><br />Also have taken apart Lower Drive and replaced the bearings & housing (for Pinion Gear). Bought a Seal Kit and replaced Seals / O-rings all over (Lower & Upper Units). Seal was bad on water pump which caused Bearings in Pinion Gear Assy. to go bad. <br /><br />Thanks for your help........
