greentahoe
- Joined
- Jul 30, 2005
- 55
I have a 1984 OMC 3.8 v-6. It gets used very little. Last year it went in the water twice. I had to change the distributor on it last year, and I very carefully set the points and timing to spec, after which it ran very well on the trailer, but I didn't have a chance to try it on the water. This Spring I've run it a few times on the trailer and it's run pretty well. It always starts up quickly and runs very smoothly. The engine has a total of about 100 hrs. on it since a total rebuild. This week I took it to the shore after adding 13 gallons of gas to that already in the tank, which was probably about 50 gallons. At the launch ramp it started fine and idled quietly and very smoothly. We headed out and I barely got it up to plane when the engine started losing power. I added more throttle, up to just over 3,000 rpm, but the engine slowed down even more. It slowed to a max. of about 2500 rpm and after about a minute or so developed some knocking noises. I checked for overheating and water pump operation, both were good. I checked the oil level, which was a little low but still enough there. Couldn't determine the exact location of the noise. The engine ran fine at low rpms, under 1300 or so, but for the rest of the day couldn't plane or if I tried anything over 2000 rpms made lots of noise. Again, no knocking at idle or low rpms. Just for information, all of the plugs, wires, distributor cap, rotor, points, condenser, and coil are new, less than an hour usage and all of that on the trailer. Also, the water separating fuel filter and the carburetor filter are new, less than an hour usage. <br />I checked the timing today and it's set at 10 degrees BTDC at 550 rpm. The oil pump is putting out 50 lbs at idle. The noise sounds like very advanced timing, but that apparently is not the case. I've checked my repair manuals and I'm growing suspiscious of my fuel, some of which has been in the tank for two years, some from last year, and some new this week. It doesn't smell sour, but could it have too low an octane and cause this problem? The manual lists low octane as a cause for this type of noise. <br />If low octane is the problem, will adding an octane booster help the situation or, and I really dread this, is it necessary to drain the tank of it's approximately 70 gallons of fuel and start fresh? <br />Thanks for the input.
