I just pulled my engine last weekend (merc 120) due to a very loud knocking noise. There was no/ very little knock at idle but when the boat was in the water and under load the knock could probably be heard from the bank with the engine cover off. The floor is in need of replacement as well so I figured it had to be pulled anyway. This is my first engine pull and teardown. So far I have started from pan up and it appears the rod bearings look ok, however 2 of the main bearings have some groves in them. The journal of the crank however looks very smooth. I have not had a chance to take the head off yet to look at the pistons but judging by the loud noise it was making i dont know if the bearings are the culprit. Is it possible for a wrist pin to make a noise such as this? I should add I did have oil pressure during this.
My plan was to sell the boat this year for something more powerful but now that the motor is out and in need of work, are there any recommended alternative engines out there that work without too much modification?
