Thanks in advance everyone, been lurking awhile, finally have a problem I haven't found the solution to from reading and searching.
I have a 1996 Merc Bravo 3 7.4L (Serial number 0F750521). While out on the lake, it started effectively shutting off. I could cruise at 3k RPM and it would lose all power, then start running again. At times it would "backfire", other times it would completely die and be difficult to restart. It made getting the boat back on the trailer interesting as it would shut off at the worst times, you know, like those last second little corrections before you make it to the trailer!
At first I thought it might be some bad gas or water in the tank and figured it would burn off eventually, but it hasn't. And I would think that water in the gas would manifest itself a little differently than a total power loss, which led me to look at the ignition system. So I replaced the cap (which had some pretty heavy deposits on the inside terminals (basically arc residue, I've seen it on cars as well), rotor, spark plugs, and based on the advice of a local boat shop, the sensor in the distributor as they felt sure that was the culprit. I also changed the fuel filter and did a full oil change with filter. The old spark plugs looked ok, maybe a little "wet" with fuel, but I had just started the boat to test the work I had done on the cap/rotor/sensor.
Took the boat for a run yesterday and really paid attention to its behavior. Before it was fully up to temp, no real issues other than its normal "grumpiness" while cold, as I think the choke is not working. Once it came up to temp, the problem with the engine cutting out started again. I kept running it and ran for about 15 minutes across the lake without a single hiccup. Then as soon as I started turning the boat it started cutting out again. Getting it back on the trailer was a 30 minute battle filled with more cursing than I am willing to admit as it just would not keep running. I could get it running, rev it in "neutral" and let it sit there like that for 5 minutes and you could hear it shutting off from time to time. Once it was pretty stable, drop the revs to idle, put it in gear, boom... shut off. The only other thing I noticed that seemed odd, is that at idle, the battery gauge would show around 13 volts (indicating it was charging) while at cruise or WOT it would often show 11 volts or as low as 10, seemed strange to me, but I honestly have no idea how accurate the gauge is. It did not seem to have that voltage drop in neutral reving to the same RPM (say 2500 RPM).
So everyone, hopefully that gives enough information to help out. The only obvious thing I know of that I haven't tried is the coil.
