First of all my boat is an '88 VIP with an 350 small block, electronic (pertronics) ignition and distributer (new 2 years ago), quadrajet 4 barrel and an OMC Cobra drive. I just replaced spark plugs (MR43T), fuel filter / water separator and a new 160 degree thermostat. Plug wires are 3 or 4 years old (all test ok with ohm meter). Fresh oil and filter as well.
The boat starting acting up a little bit at the end of last season and has continued to do so for the 1st two times I have taken it out this year. It starts up GREAT, and runs FINE as soon as I get to the lake. However, it seems like after I am out on the water for about 45 min - 1 hr, especially after I have been sitting (with the boat off) for awhile it starts cutting out and missing. I can't tell if it is getting too much or too little fuel, or not running on all cylinders or what. Today it started doing it when I was just cruising along at about 2800 RPM. I took a short video of the engine when it was acting up and it can be seen at this link:
http://www.americaninspections.net/andy/video.htm
(just right click on the link and then click "Save Target As" and you can download and view the video) And, yes I know the flame arrestor is off, I wanted to make sure the choke was interferring, but it was wide open like it ought to be.
The carb has not been re-built since I have owned the boat ~4-5 years. But it seems like if it was the carb it would ALWAYS do it, and not be in consistent like this. Like I say, if I take it out tomorrow it will probably run start and run like a champ for the first half hour!
Any help or suggestions ARE REALLY appreciated. I want to get things running properly before the warmer weather gets here! Thanks!
Andy
Andy
