Engine Mount Nuts
Rich Novak
1988 mercruiser v6 205 hp.
Trying to align the engine.
Question is,
What size is the nuts holding motor to the motor mounts .
I tried 1, 1.1/8. 1 1/6. 27 mm. No luck
Thanks,Rich
Rich Novak
1 1/16 usually unless there heavily rusted
I tried 1 1/6 w
Wrench kept slipping off.
The nut is.
About. Half the size of a reg. Nut is also looks to have a washer built on .
The nuts are all the way down so I have to use a closed end wrench.
My engine has to go down but not much room if any.
Is it possible to raise the rear to align it.
Rich Novak
I don't think it is collapsed, it looks like the one in the. Manual
Bt Doctur
When the rear mounts are installed in the housing they protrude beneath the housing and the fibre washer should be able to spin around. When it fails the rear mount squats down on this washer.
Have a housing with bad mounts, will post a pic tomorrow. Another way to tell is by removing the rear bolts and feeling if the bushings are the same recessed height.
